PROBLEM
Application conflict when simultaneously running PCTools Threatfire 4.0.0.10 and McAfee Virus Scan
A conflict occurs when McAfee Virus Scan operates on a machine using Threatfire Virus Scan.
When these anti-virus applications run simultaneously, most of the ArcGIS 9.3 Geoprocessing tools in ArcToolbox, as well as many exporting functions, generate a generic 99999 error and do not function.
Cause
PC Tools Threatfire 4.0.0.10 and later versions are causing a conflict when it is run simultaneously with McAfee Virus Scan.
Solution or Workaround
Disabling the virus scanning capabilities of the Threat Fire application allows the tools in the ArcToolbox to work properly, after restarting ArcGIS 9.3.
  1. Right-click the Threat Fire icon in Windows task bar.
  2. Select 'Disable' from the drop-down menu. This temporarily disables the scanning function of the application and allows the tools in ArcToolbox to function properly.
Article ID:000010495
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
