English
Bug: When ArcMap is started by double-clicking on a map template or .mxt file, the startup dialog box still appears
When ArcMap is started by double-clicking on a map template or .mxt file, the startup dialog box still appears.
Cause
This is a known issue.
Workaround
There is no known workaround at this time.
