BUG
Applying a map template (.mxt file) that uses 'Use Printer Paper' settings sets the paper size to that of the installed default printer
Applying a map document template or .mxt file that uses 'Use Printer Paper' changes the map page size to that of the default paper size of the default printer installed on the computer.
Cause
This is a known issue.
Workaround
  1. Open ArcMap with a new, empty map.
  2. Navigate to File, then browse to and open the template (.mxt) file.
    The page size and printer information are retained in Page and Print setup.
Article ID:000010489
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
