English
Bug: In ArcMap, using 'Save a Copy' of an .mxd from version 9.3 to version 9.2 results in rasters that cannot be viewed in version 9.2
In ArcMap 9.3, when a copy is saved to version 9.2 using 'Save a Copy', the resultant .mxd file may contain rasters that disappear in the table of contents as well as in the map extent.
Cause
Using ArcMap 9.3 'Save a Copy' function to save a map document to a version 9.2 .mxd file results in rasters not being translated correctly when opened in version 9.2.
Workaround
The .mxd files saved for version 9.2 from version 9.3 may contain rasters that cannot be viewed in version 9.2.
Re-open the .mxd file in the version 9.3 client to view the raster.
