English
Bug: DBMS table not found (-37)
The 'sdegcdrules -o list' command fails on a DBO schema, returning the following error:
ArcSDE 9.2, ArcSDE 9.3, ArcSDE 9.3.1 for SQL Server 2005 or SQL Server 2008 DBO schema are unable to list the geocoding rule files and report the error.
Cause
The 'sdegcdrules -o list' command fails on a DBO schema.
When running an sde post installation to create an sde database with a DBO schema using a Windows authentication and then running 'sdegcdrules -o list', the following error message returns:
C:\Documents and Settings\ssluser>sdegcdrules -o list -i 7272
ArcSDE 9.3 for SQL Server Build 546 Thu Sep 18 12:35:50 2008
Geocoding Rule Table Administration Utility
Error: DBMS table not found (-37).
Error: Cannot list entries in the geocoding rule table.
Workaround
Create a new database with a SDE schema.
