English
Error: ld.so.1: sdemon: fatal: libmtsk.so.1: open failed: No such file or directory
Error Message
During the post installation process for ArcSDE 9.3 or 9.3.1, running the 'sdesetup -o install' command or 'sdesetup -o upgrade' command, returns the following error message:
"ld.so.1: sdemon: fatal: libmtsk.so.1: open failed: No such file or directory".
Cause
ArcSDE 9.3 or 9.3.1 on Solaris requires a patch to work properly.
Solution or Workaround
Download and apply the appropriate Solaris patch:
For Solaris 9: Patch 117560-06
For Solaris 10: Patch 120753-07
