PROBLEM
ArcMap and ArcCatalog are slow when drawing or loading shapefiles
ArcMap and ArcCatalog are slow when drawing or loading shapefiles.
Cause
While this may be due to several reasons, one cause is if Microstation or AutoCAD plug-in Eagle Point is installed.
Solution or Workaround
Uninstall Eagle Point.
    Article ID:000010472
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
