English
Error: ORA-00932: inconsistent datatypes: expected SDE.ST_GEOMETRY got MDSYS.ST_POINT
Error Message
If the st_geometry type or operators are not fully qualified with the SDE owner and Oracle spatial is installed in the Oracle database, the following Oracle error will be encountered:
"ORA-00932: inconsistent datatypes: expected SDE.ST_GEOMETRY got MDSYS.ST_POINT."
Code:
SQL> INSERT INTO manholes (objectid, shape)
2 VALUES (1024, st_point('1395754.752 405415.412',4));
ERROR at line 2:
Cause
If the st_geometry operator is not fully qualified when public synonyms for the st_geometry type and operators do not exist, and Oracle spatial is installed in the Oracle database, Oracle maps st_geometry operators to its own st_geometry type owned by the MDSYS user.
Solution or Workaround
Always fully qualify all st_geometry operators with the type and operator owner SDE, for example, sde.st_point or sde.st_intersects.
    Related Information
