The Find tool returns incorrect results or no results when a layer contains a GlobalID and/or a GUID field.
Cause
This is a known issue.
Workaround
Turn off the GlobalID/GUID field visibility or remove the GlobalID/GUID field and perform the find again.
- Right-click on the layer that contains the GlobalID/GUID field and select Properties.
- Click the Fields tab.
- Located the GlobalID and/or GUID field(s) and click the check box to uncheck it.
