English
How To: Change ArcSDE dbtune parameters
Summary
ArcSDE dbtune parameters can be changed or modified using the ArcSDE command sdedbtune -o alter or by modifying the dbtune file and importing the file using the ArcSDE command sdedbtune -o import.
Procedure
To change the ArcSDE dbtune parameters, use one of the following steps:
  1. Using the ArcSDE command sdedbtune -o alter:
    Code:
    Example of changing the geometry_storage parameter under the DEFAULTS keyword:
    sdedbtune -o alter -k DEFAULTS -P geometry_storage -v SDEBINARY -i esri_sde -u sde -p sde
    ArcSDE 9.2 for Oracle10g Build 1271 Tue Jun 24 07:47:53 2008
    Attribute Administration Utility
    Update DBTUNE data. Are you sure? (Y/N): y
    Successfully altered dbtune data.
    To confirm the parameter value was changed execute the following command:
    Code:
    sdedbtune -o list -k DEFAULTS -i esri_sde -u sde -p sde
    ##DEFAULTS
    A_INDEX_RASTER "PCTFREE 0 INITRANS 4 NOLOGGING "
    GEOMETRY_STORAGE "SDEBINARY"
    END
  2. Using the ArcSDE command sdedbtune -o import:
    After modifying the dbtune.sde file located in the SDEHOME directory, import the file into the ArcSDE instance using the following example:
    Code:
    sdedbtune -o import -f C:\ArcGIS\ArcSDE\ora10
    gexe\etc\dbtune.sde -i esri_sde -u sde -p sde
    Import DBTUNE Table. Are you sure? (Y/N): y
    Successfully imported from file "C:\ArcGIS\ArcSDE\ora10gexe\etc\dbtune.s
    de"
Related Information
