PROBLEM
Web Application images fail to draw or display broken links
When viewing applications built with the ArcGIS Server Web ADF for the Microsoft .NET Framework, several map elements such as the Map, TOC, OverviewMap and ScaleBar always fail to draw or display broken links.
[O-Image] [O] Broken link
Cause
The MIME handlers needed to display images did not install successfully.
Solution or Workaround
  1. Open a command prompt window. If running Vista or Windows 2008, use the 'Run as Administrator' option to open the command prompt window.
    [O-Image] Run As Administrator
  2. Navigate to <InstallDir>\arcgis\DotNet.
    Code:
    C:\Windows\system32>cd c:\arcgis\DotNet
    c:\arcgis\DotNet>
  3. Execute the following command syntax:
    Code:
    c:\arcgis\DotNet>adfutil -registerADF
  4. Restart IIS.
    Code:
    c:\arcgis\DotNet>iisreset
Article ID:000010429
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
