ERROR
Could not create the handler named: 'esri.imageserver.serviceeditor.serviceeditorcmdhandler'. (COM error: 0x80040154)
Error Message
During the compilation of an image service, the following error message is received:
"Could not create the handler named: 'esri.imageserver.serviceeditor.serviceeditorcmdhandler'. (COM error: 0x80040154)".
Cause
All, or a few, of the following DLLs exist in the folder C:\WINDOWS\system32 and may have older or different versions than required.
pe.dll
sde.dll
sg.dll
Solution or Workaround
Navigate to the C:\WINDOWS\system32 folder and see if any of the above listed DLLs exist in this folder. If they do, rename the DLLs to new names, such as pe_old.dll, sde_old.dll, and sg_old.dll, and recompile the service.
    Article ID:000010419
    Software:
    • ArcGIS Server
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
