English
Error: ev.SQLstate = 42P01 SDE DBMS Error: -37 ERROR: relation "sde.sde_server_config" does not exist
Error Message
When setting up ArcSDE for PostgreSQL repository tables, either through the Post Installation or with sdesetup -o install, errors are recorded in the sde_setup.log which is found in the SDEHOME\etc directory.
Code:
[Fri May 30 20:17:18 2008] ev.SQLstate = 42P01
SDE DBMS Error: -37 ERROR: relation "sde.sde_dbtune" does not exist
Cause
ArcSDE for PostgreSQL checks for the existence of these tables before proceeding with the sde repository setup.
Solution or Workaround
This behavior is normal and should not affect the performance of the ArcSDE geodatabase.
