HOW TO
Instructions provided describe how to produce the recommended reconcile order using SQL in Oracle. The output from the query is the order that versions should be reconciled with the sde.DEFAULT version prior to performing a compress. By reconciling the versions in the order returned by the query, it allows the compress command to move as many rows as necessary from each versioned class delta tables to the base tables.
Using the SQL approach is the same as if using the ArcObjects interface IVersionedWorkspace2::RecommendedReconcileOrder to obtain an enumeration of version names.
The steps should be performed by the sde administrative user in SQL*Plus.
Code:
SQL> DROP TABLE version_order;
ERROR at line 1:
ORA-00942: table or view does not exist
Code:
SQL> CREATE GLOBAL TEMPORARY TABLE version_order (
2 owner VARCHAR2(32),
3 name VARCHAR2(64),
4 state_id NUMBER(38),
5 ca_state_id NUMBER(38))
6 ON COMMIT PRESERVE ROWS;
Table created.
Code:
CREATE OR REPLACE PROCEDURE common_ancestor_exe AS
CURSOR ver_list IS
SELECT name, owner, state_id
FROM sde.versions
WHERE name <> 'DEFAULT'
AND name NOT LIKE 'SYNC_%'
AND name NOT LIKE 'REP_CO_SYNC_%'
ORDER BY state_id;
default_id NUMBER;
default_lin NUMBER;
source_lin NUMBER;
common_ancestor_id NUMBER;
BEGIN
SELECT state_id, lineage_name INTO default_id, default_lin FROM sde.states WHERE state_id =
(SELECT state_id FROM sde.versions WHERE name = 'DEFAULT' AND owner = 'SDE');
DELETE FROM version_order;
FOR ver_info IN ver_list LOOP
SELECT lineage_name INTO source_lin FROM sde.states WHERE state_id = ver_info.state_id;
SELECT MAX(lineage_id) INTO common_ancestor_id FROM
(SELECT lineage_id FROM sde.state_lineages WHERE lineage_name = default_lin AND lineage_id <= default_id
INTERSECT
SELECT lineage_id FROM sde.state_lineages WHERE lineage_name = source_lin AND lineage_id <= ver_info.state_id);
IF common_ancestor_id < default_id THEN
INSERT INTO version_order VALUES (ver_info.owner, ver_info.name, ver_info.state_id, common_ancestor_id);
END IF;
END LOOP;
COMMIT;
END;
Code:
EXEC sde.common_ancestor_exe;
PL/SQL procedure successfully completed.
Code:
SQL> SELECT owner, name
2 FROM version_order
3 ORDER BY ca_state_id, state_id;
OWNER NAME
RANDY REV_6847258
CHRIS REV_7019237
CLARE REV_7069544
LUCY REV_7043793
SUSAN REV_7069206
Get help from ArcGIS experts
Download the Esri Support App
