English
Error: Error 1721: there is a problem with this windows installer package
Error Message
When uninstalling ArcGIS Desktop, the following error appears:
"Error 1721: there is a problem with this windows installer package."
Cause
This error occurs when the installation of ArcGIS Desktop has become corrupt.
Solution or Workaround
Run a repair on ArcGIS Desktop, and then uninstall ArcGIS Desktop.
  1. Insert the ArcGIS Desktop installation disk.
  2. Navigate to Start > Control Panel > Add/Remove Programs.
  3. Select ArcGIS Desktop from the list and click Change.
  4. Select the Repair option.
  5. Complete the ArcGIS Setup wizard to run a repair.
  6. Uninstall ArcGIS Desktop by way of Add/Remove Programs in the Control Panel.
Related Information
