HOW TO
Import an XML document created when using disconnected replication
Summary
When creating a replica in a disconnected environment, the method used is creating an XML document through the Create Replica wizard. After the replica is created, it needs to be sent to the relative geodatabase by some transfer medium such as CD or DVD. The relative geodatabase then needs to import the XML document to finalize the create replica process.
Procedure
To import the XML document created during the replica creation process, the standard 'Import XML Workspace Document' tool should be used.
  1. Right-click on the database connection for the child replica.
  2. Click Import > XML Workspace Document...
  3. Choose to import Data.
  4. Click Next > Click Finish.
Article ID:000010371
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
