English
Bug: ArcGIS 9.3 SP1 Java ADF application containing EditingTask does not work in Firefox if the STATE_SAVING_METHOD is set to client in web.xml file
If the javax.faces.STATE_SAVING_METHOD is set to "client" as shown below in the web.xml file, the ArcGIS 9.3 Service Pack 1 (SP1) Java ADF application containing EditingTask does not work in a Mozilla Firefox browser.
<context-param>
<param-name>javax.faces.STATE_SAVING_METHOD</param-name>
<param-value>client</param-value>
</context-param>
When opening the above application in Firefox browser, it generates the following exception in the web server logs and it displays “The application encountered an error. Please check server logs for additional information.” message in the browser.
- Unexpected end of ZLIB input stream
java.io.EOFException: Unexpected end of ZLIB input stream
at java.util.zip.InflaterInputStream.fill(InflaterInputStream.java:216)
at java.util.zip.InflaterInputStream.read(InflaterInputStream.java:134)
at java.util.zip.GZIPInputStream.read(GZIPInputStream.java:87)
at java.io.ObjectInputStream$PeekInputStream.read(ObjectInputStream.java:2213)
at java.io.ObjectInputStream$PeekInputStream.readFully(ObjectInputStream.java:2226)
at java.io.ObjectInputStream$BlockDataInputStream.readUTFBody(ObjectInputStream.java:2963)
at java.io.ObjectInputStream$BlockDataInputStream.readUTF(ObjectInputStream.java:2764)
at java.io.ObjectInputStream.readString(ObjectInputStream.java:1567)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1296)
at java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:1908)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1832)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1719)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1305)
at java.io.ObjectInputStream.readArray(ObjectInputStream.java:1634)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1299)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java:348)
at com.sun.faces.renderkit.ResponseStateManagerImpl.getTreeStructureToRestore(ResponseStateManagerImpl.java:154)
at com.sun.faces.application.StateManagerImpl.restoreTreeStructure(StateManagerImpl.java:374)
at com.sun.faces.application.StateManagerImpl.restoreView(StateManagerImpl.java:260)
at com.sun.faces.application.ViewHandlerImpl.restoreView(ViewHandlerImpl.java:250)
at com.sun.faces.lifecycle.RestoreViewPhase.execute(RestoreViewPhase.java:177)
at com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.java:245)
at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:110)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:213)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at com.esri.adf.web.util.ADFFilter.doFilter(Unknown Source)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at com.esri.adf.web.util.ADFSessionTimeoutFilter.doFilter(Unknown Source)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:874)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
at java.lang.Thread.run(Thread.java:595)
Cause
This is a known issue.
Workaround
This problem can be worked around either by:
  • Using Internet Explorer 6/7 browser
  • Setting the STATE_SAVING_METHOD property to "server" in the web.xml file as shown below:
    <context-param>
    <param-value>server</param-value>
    </context-param>
