English
How To: Disable archiving for an ArcSDE geodatabase object class
Summary
Instructions provided describe how to disable archiving for an ArcSDE geodatabase object class. By default, there is no option to disable archiving when right-clicking for the context menu, when working with an ArcSDE geodatabase object class.
Procedure
  1. In ArcCatalog, go to Tools > Customize.
  2. Select the 'Toolbars' tab and check 'Context Menus' to open the Context toolbar.
    [O-Image] context
  3. Click the 'Commands' tab.
  4. Scroll to and select 'Geodatabase Tools' under 'Categories'.
  5. On the left, under 'Commands', select 'Disable Archiving...'.
    [O-Image] Disable
  6. Click the 'Context Menus' drop-down menu and navigate to 'Enterprise Table Context Menu'.
    [O-Image] Context_2
  7. Click and drag the 'Disable Archiving...' to the desired location within the 'Enterprise Table Context Menu'.
    [O-Image] Context_3
    Now, when right-clicking on an ArcSDE geodatabase object class, 'Disable Archiving...' is available.
