PROBLEM
Newly installed fonts do not display in an ArcGIS Server map service
When a newly installed font is used for the symbology or labels in a map document published to ArcGIS Server, the new font does not display in the service. Although the font has been installed on the ArcGIS Server SOC machine and works in other applications on that machine, the map service displays the characters using a different font.
Cause
A system restart is required to properly display newly installed fonts with ArcGIS Server.
Solution or Workaround
Reboot the ArcGIS Server SOC machine to allow the font to be properly rendered in the map service.
    Article ID:000010356
    Software:
    • ArcGIS Server
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
