English
Problem: The sde.state_lineages table is no longer present in the ArcSDE instance
When starting an ArcSDE service, the process fails and the following warning message is present in the ArcSDE error log:
Code:
ArcSDE 9.3 for Oracle10g Build 545 Wed Sep 17 12:35:52 2008
ST_Geometry Schema Owner: (SDE) Type Release: 1007
Instance initialized for ((sde)) . . .
Connected to instance . . .
Error locating ArcSde system tables and stored procedures (STATE_LINEAGES).
Run ArcSde setup utility (sdesetup*) before starting giomgr.
The message indicates the ArcSDE repository table state_lineages is not present and the service is unable to start.
Cause
If the ArcSDE repository table state_lineages is not present when the instance is started, the instance startup fails and prints the error to the ArcSDE error log.
The state_lineages table is a required table used by the geodatabase versioning implementation. The table maintains each state's lineage_name and is used in each version query to derive a state's lineage.
Solution or Workaround
If this error is encountered when starting the ArcSDE service, it is necessary to execute the ArcSDE setup utility to create the state_lineages table. If there are pre-existing states in the instance, the sdesetup utility will populate the state_lineages table with the appropriate values for each state.
Explicitly dropping the state_lineages table and running sdesetup can be used as a workflow to fix any inconsistencies in the ArcSDE state_lineages table. Prior to proceeding, make sure a backup of the ArcSDE instance exists in case of any unexpected failures.
The ArcSDE sdesetup utility needs to be run by the ArcSDE administrator from an operating system command prompt.
Code:
D:\>sdesetup -o upgrade -d oracle10g -H d:/esri/arcsde/ora10gexe -u sde -N
Enter DBA password:
ESRI ArcSDE Server Setup Utility Thu Oct 16 14:06:28 2008
Upgrading ArcSde schema.....
Successfully upgraded ArcSde schema.
Upgrading locators.....
Successfully upgraded locators.
Upgrading geodatabase schema:
Successfully upgraded geodatabase schema.
Successfully upgraded ArcSDE instance.
Refer SDEHOME\etc\sde_setup.log for more details.
The sdesetup in this case uses the -o upgrade option since the ArcSDE instance is pre-existing.
