English
Error: Error 1704 An installation for ArcGIS Desktop is currently suspended
Error Message
When installing ArcGIS Desktop, the following error is encountered:
"Error 1704
An installation for ArcGIS Desktop is currently suspended.
Do you want to undo those changes? yes/no"
Cause
This typically occurs when the previous version of ArcGIS Desktop was not completely uninstalled prior to installing the newer version of ArcGIS Desktop.
Solution or Workaround
Click 'Yes' to the error message, and allow the rollback to occur. The installation then proceeds normally.
