BUG
Left justify is ignored with legend items when the legend title is long
If the legend title is long, setting left justification for the legend title and legend items in the Legend Wizard is ignored. The legend title and items display as centered.
For example, the left justification option is selected in the Title Justification section to correspond with the rest of the legend:
[O-Image] Legend Wizard
However, the legend items still display centered and not left justified:
[O-Image] Legend not justified
Cause
This is a known issue.
Workaround
If the legend does not have a border, use the first bulleted procedure below to add a graphic text element instead of a legend title.
If the legend does have a border, use the second bulleted procedure below to convert the legend to graphics and shift the legend items or title as desired.
  • To have the legend items left justified when using a long legend title without a legend border:
    1. Double-click the legend in Layout view.
    2. In the Legend Properties dialog box, click the Legend tab and delete the existing title.
    3. Click OK.
    4. Click the text button on the Drawing toolbar and enter the text above the legend as the legend title:
    [O-Image] Graphic text entered as a legend title
    5. Place legend title text at the desired location.
  • To have the legend items left justified when using a long legend title with a legend border:
    1. Right-click on the legend and select 'Convert to Graphics'.
    2. Right-click again on the legend graphic and select 'Ungroup'.
    3. Select the legend items. Click and drag them or use the keyboard left/right arrow keys to move them to the desired location within the border.
    [O-Image]
    4. Select all the legend graphic elements, including the title, items and border.
    5. Right-click on the selected elements and select 'Group'.
Article ID:000010313
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
