HOW TO
Instructions provided describe how to list all connected sessions and report how long the sessions have been idle (the length of time since the session last executed a SQL statement).
Note: ArcSDE software, including the application server, command tools, and SDK with C and Java APIs, was deprecated at ArcGIS 10.2.2 and is no longer distributed. ArcGIS software features were deprecated, rather than immediately removed, to provide customers with backward compatibility and give as much advance notice as possible to adopt newer technology.
Code: SQL> DECLARE 2 3 CURSOR session_cursor IS 4 SELECT username, sid, last_call_et 5 FROM v$session 6 WHERE username IS NOT NULL AND username NOT IN ('SYS','SYSTEM') 7 ORDER BY last_call_et; 8 9 num_mins NUMBER; 10 num_mins_sec NUMBER; 11 wait_secs NUMBER; 12 num_hours NUMBER; 13 num_hours_min NUMBER; 14 wait_mins NUMBER; 15 num_days NUMBER; 16 num_days_hours NUMBER; 17 wait_hours NUMBER; 18 wait_char_mins VARCHAR2(4); 19 wait_char_secs VARCHAR2(4); 20 21 BEGIN 22 23 DBMS_OUTPUT.PUT_LINE(chr(10)); 24 25 FOR idle_time IN session_cursor LOOP 26 27 -- Total number of seconds waited... 28 29 num_mins := trunc(idle_time.last_call_et/60); 30 num_mins_sec := num_mins * 60; 31 wait_secs := idle_time.last_call_et - num_mins_sec; 32 33 -- Total number of minutes waited... 34 35 num_hours := trunc(num_mins/60); 36 num_hours_min := num_hours * 60; 37 wait_mins := num_mins - num_hours_min; 38 39 -- Total number of hours waited... 40 41 num_days := trunc(num_hours/24); 42 num_days_hours := num_days * 24; 43 wait_hours := num_hours - num_days_hours; 44 45 DBMS_OUTPUT.PUT('User '||idle_time.USERNAME||'('||idle_time.SID||') has been idle for '||num_days||' day(s) '||wait_hours||':'); 46 47 IF wait_mins < 10 THEN 48 wait_char_mins := '0'||wait_mins||''; 49 DBMS_OUTPUT.PUT(''||wait_char_mins||':'); 50 ELSE 51 DBMS_OUTPUT.PUT(''||wait_mins||':'); 52 END IF; 53 54 IF wait_secs < 10 THEN 55 wait_char_secs := '0'||wait_secs||''; 56 DBMS_OUTPUT.PUT(''||wait_char_secs||''); 57 ELSE 58 DBMS_OUTPUT.PUT(''||wait_secs||''); 59 END IF; 60 61 DBMS_OUTPUT.NEW_LINE; 62 63 END LOOP; 64 65 END; 66 / User usdomain\tb(145) has been idle for 0 day(s) 0:54:46 User AGSSERVER(152) has been idle for 0 day(s) 0:54:46 User SNOOPY(151) has been idle for 1 day(s) 8:56:03 User SDE(137) has been idle for 3 day(s) 3:17:16 PL/SQL procedure successfully completed.The output shows user usdomain\tb, with Oracle sid (145), has been idle for 0 days, 54 minutes and 46 seconds, whereas the SDE user, Oracle sid (137), has been idle for 3 days, 3 hours, 17 minutes and 16 seconds.
Get help from ArcGIS experts
Download the Esri Support App
