English
Bug: Top and left-hand sides of raster information in the map are cropped off when printing or exporting from ArcMap
The top and left-hand sides of raster information that uses the statistics option 'From Current Display Extent' in the map are cropped off when printing or exporting from ArcMap.
For example, the map displays correctly in ArcMap Layout.
[O-Image] Map displays correctly in ArcMap
However, when exported to PDF, the top and left-hand sides are cropped.
[O-Image] PDF displays clipped.
Cause
This is a known issue when using 'From Current Display Extent' on raster data at 9.3.
Workaround
Use the workaround in the ESRI Knowledge Base article listed in the Related Information section below.
    Related Information
