English
Error: An unhandled exception ('System.IO.IOException') occurred in CodeConverterUtil.exe [3656]
Error Message
When installing the Web Applications or Web Application Developer Framework features of ArcGIS Server for the Microsoft .NET Framework 9.3 on a machine with Visual Studio Team System 2008 Test Edition, the software install fails with the following error:
"An unhandled exception ('System.IO.IOException') occurred in CodeConverterUtil.exe [3656]"
Cause
Visual Studio Team System 2008 Test Edition is not a supported development environment.
Solution or Workaround
Visual Studio 2008 Professional and Standard editions are supported development environments.
Learn more about the supported environments with ArcGIS Server on the System Requirements page.
