Frequently asked question
Why is an error returned when SetCurrentLayer is called after installing ArcGIS 9.3 Service Pack 1?
Answer
At ArcGIS 9.3 Service Pack 1, the SetCurrentLayer method found on the IEditLayers interface has been changed, so that it requires a valid layer and subtype value. An error will be raised if an invalid subtype code is passed. The exception to this change is when a shapefile is the current layer, a subtype value of 0 can be passed, because shapefiles do not support subtypes.
Use the following code to set the current layer when unsure of the default subtype.
Code:
Dim psubtypenum As ISubtypes
Dim subtype As Integer
If TypeOf pfeatClass Is ISubtypes Then
Set psubtypenum = pfeatClass
subtype = psubtypenum.DefaultSubtypeCode
Else
subtype = 0
End If
pEditLayers.SetCurrentLayer pFeatLayer, subtype
Article ID:000010276
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
