English
How To: Copy the import profiles from one machine to another
Summary
Instructions provided describe how to move the import profiles of ArcLogistics Route from one machine to another.
Procedure
The import profiles are stored in the registry, so they can be exported to a .reg file using regedit on one machine and imported on the other machine.
Warning:
WARNING! This article contains instructions to make specific changes to essential parts of your operating system. If these specific changes are not done correctly, it may cause serious problems to your computer operating system and files. First, ESRI recommends that you make a complete backup of your system, including the registry, before implementing any of the specific changes. It is highly recommended that you consult with your IT/MIS department, or other qualified computer systems professional before proceeding. ESRI cannot guarantee that you can solve problems that result from incorrect use of the Registry Editor utility. Use the Registry Editor utility at your own risk. Note: your operating system and any subsequent service packs may effect these instructions. These instructions are subject to change without notice.
  1. On the source machine, go to the Start Menu and select Run. Type regedit and press Enter.
  2. Navigate to HKEY_CURRENT_USER\Software\ESRI\ArcLogisticsRoute\ImportDefinitions.
  3. Right-click the ImportDefinitions folder and select Export. This exports a .reg file.
  4. Copy the .reg file to the destination machine. Double-click the .reg file and add the entries to the registry.
Related Information
