English
Error: Cannot open socket for listening, -102
Error Message
In ArcSDE 9.3 for SQL Server, when starting an ArcSDE service, the following error displays:
"Cannot open socket for listening, -102"
Cause
The ArcSDE service name and port number pairs are inconsistent between the
%SDEHOME\etc services.sde and the C:\WINDOWS\SYSTEM32\DRIVERS\ETC\service.
Solution or Workaround
Compare the ArcSDE service entries in the
%SDEHOME%\etc services.sde file and ArcSDE service entries in the C:\WINDOWS\SYSTEM32\DRIVERS\ETC\services file to make sure they are consistent.
  1. Open the %SDEHOME%\etc\services.sde file.
    For example:
    C:\Program Files\ArcGIS\ArcSDE\sqlexe\etc\services.sde
    Code:
    /* $Id: services.sde,v 1.2 1999/01/22 01:01:35 donna Exp $ */
    # ESRI SDE Remote Protocol
    # Note: uncomment the line below to use ESRI's default port
    esri_sde 5151/tcp
  2. Open C:\WINDOWS\SYSTEM32\DRIVERS\ETC\service file.
    For example:
    Code:
    # Copyright (c) 1993-1999 Microsoft Corp.
    # This file contains port numbers for well-known services defined by IANA
    # Format:
    # <service name> <port number>/<protocol> [aliases...] [#<comment>]
    echo 7/tcp
    echo 7/udp
    discard 9/tcp sink null
    discard 9/udp sink null
    systat 11/tcp users #Active users
    knetd 2053/tcp #Kerberos de-multiplexor
    man 9535/tcp #Remote Man Server
    esri_sde 5151/tcp #ArcSDE for SQL Server
    Make sure the ArcSDE service entry in the two files has the same service name and port number, in this case 'esri_sde' and '5151/tcp'.
