English
FAQ: What are the required permissions for ArcGIS Business Analyst extension?
Question
Answer
There are several registry keys and folders that are required to have full control/read permissions for the following versions of ArcGIS Business Analyst extension.
The following are the folders that are required for full read/write permissions for all ArcGIS Business Analyst versions:
C:\Program Files\ArcGIS
C:\My Output Data (or other specified folder that can be changed from the default system drive in ArcGIS Business Analyst preferences)
The following are the registry keys that are required for full control/read permissions.
For ArcGIS Business Analyst build versions #9.2.303 and newer:
HKEY_LOCAL_MACHINE\SOFTWARE\ESRI\BusinessAnalyst
HKEY_CURRENT_USER\Software\ESRI\BusinessAnalyst
For ArcGIS Business Analyst build versions #9.2.151 and older:
Related Information
