English
Error: Cannot run lmutil.exe located under C:\Documents and Settings\...utilities
Error Message
When trying to install the ArcGIS License Manager, the following error message is displayed:
"Cannot run lmutil.exe located under C:\Documents and Settings\...utilities"
Cause
The installer is not able to run on this path.
Solution or Workaround
Change the user environment variables TMP and TEMP to C:\temp.
Instructions provided in the Knowledge Base article, How To: Edit an environment variable, describe how to edit environment variables for various platforms.
