English
Bug: Attempting to create a selection set with a view in Oracle with an st_geometry attribute kills the ArcSDE gsrvr process
When working with a spatial view in ArcMap that was created with the ArcSDE administration command sdetable -o create_view and performing a selection that results in an ArcSDE log file, the ArcSDE gsrvr process crashes.
Cause
A memory overwrite in the ArcSDE gsrvr results in the process crashing.
Workaround
Avoid creating large selection sets with spatial views that result in the creation of an ArcSDE log file.
