English
Bug: The ArcMap title bar does not reflect the current ArcGIS seat type
The ArcMap title bar does not reflect the current ArcGIS seat type when using the environment variable ESRI_SOFTWARE_CLASS. The title bar always shows the seat type selected during installation.
Cause
This is a known issue.
Workaround
This issue is resolved at ArcGIS 9.0.
To determine which seat type is currently selected, check the environment variable.
    Related Information
