English
Error: Print statements inside an in-process script tool cause error
Error Message
Running in-process python scripts in ArcToolbox produces the following error:
"<type 'exceptions.IOError'>: [Errno 9] bad file descriptor".
Cause
Print statements inside a loop within the script; for example, when using Cursors.
Code:
import arcgisscripting
gp = arcgisscripting.create(9.3)
for x in range(1,2500):
gp.addmessage(str(x)) # this line only necessary to track where it fails
print x
Solution or Workaround
The following are known solutions to this issue:
  • Comment out or remove the print statements.
  • Wrap the print statements in a try/except, such as in the example below:
    Code:
    try:
    print "some statement"
    except IOError:
    pass
