English
Error: Windows Installer has stopped working. A problem caused the program to stop working correctly.
Error Message
When installing ArcGIS Desktop or ArcInfo Workstation on Windows Vista, the following error is encountered:
"Windows Installer has stopped working.
Windows will close the program and notify you if a solution is available."
"Windows Installer was closed.
To help protect your computer DEP has closed Windows Installer."
Cause
The Windows Installer is at an older version or has become corrupt.
Solution or Workaround
Install version 4.5 of the Windows Installer and reboot the machine. The download link can be found in the Related Information section below.
    Related Information
