ERROR
When using a Web Mapping Application built with the 9.3 .NET Web ADF, clicking the FullExtent button or using the ZoomTo/PanTo options on a task result can crash the application with the following error:
"Application Error
Object reference not set to an instance of an object.
ESRI.ArcGIS.ADF.Web.Geometry.TransformationParams..ctor(Envelope extent,
Int32 viewWidth, Int32 viewHeight, Double mapRotationInDegrees,
TransformationDirection direction, SpatialReference spatialReference) at
ESRI.ArcGIS.ADF.Web.UI.WebControls.OverviewMap.getTransformationParams
(TransformationDirection direction)"
The OverviewMap's OverviewMapResource property is not set to a valid resource item.
This can easily occur when the map resource item that the OverviewMap is set to display is renamed or deleted in the MapResourceManager.
Get help from ArcGIS experts
Download the Esri Support App
