English
Problem: Tools on ArcPad Data Manager toolbar are grayed out
After adding the ArcPad Data Manager toolbar to ArcMap, the buttons are grayed out.
[O-Image]
Cause
The toolbar needs to be activated prior to use.
Solution or Workaround
Activation of the Data manager toolbar is the same as activating an extension.
ArcGIS 10:
Navigate to Customize > Extensions and check the box next to ArcPad Data Manager.
ArcGIS 9.3.1 and earlier:
Navigate to Tools > Extensions and check the box next to ArcPad Data Manager.
[O-Image]
This needs to be done in both ArcMap and ArcCatalog.
