English
Error: Unable to save edits. Logfile not found [SDE.DEFAULT]
Error Message
While editing data stored in an ArcSDE for Oracle geodatabase the following error is received when saving edits:
"Unable to save edits.
Logfile not found[SDE.DEFAULT]".
Cause
This error can occur when the ArcSDE geodatabase is stored in Oracle and session pooled logfile tables are being used.
An example of this configuration is shown below:
ALLOWSESSIONLOGFILE TRUE
LOGFILEPOOLSIZE 20
Solution or Workaround
For most Oracle DBMS geodatabases, shared ArcSDE logfiles is recommended and is the default setting. If session logfiles is a requirement due to workflow or other restrictions, then using the session temp logfiles is another option.
Using the sdeconfig -o alter command, the parameters associated with configuring ArcSDE logfiles can be adjusted.
  1. To configure shared logfiles:
    Code:
    sdeconfig -o alter -v MAXSTANDALONELOGS=0 -i <service> -s <server_name> -D <database> -u <DB_User_name> -p <DB_User_password> -N -q
    sdeconfig -o alter -v ALLOWSESSIONLOGFILE=FALSE -i <service> -s <server_name> -D <database> -u <DB_User_name> -p <DB_User_password> -N -q
  2. To configure session temp logfiles:
    Code:
    sdeconfig -o alter -v LOGFILEPOOLSIZE=20 -i <service> -s <server_name> -D <database> -u <DB_User_name> -p <DB_User_password> -N -q
    sdeconfig -o alter -v ALLOWSESSIONLOGFILE=TRUE -i <service> -s <server_name> -D <database> -u <DB_User_name> -p <DB_User_password> -N -q
    The LOGFILEPOOLSIZE parameter can be adjusted according to the number of connections for best performance.
Related Information
