HOW TO
Increase the maximum number of unique values allowed in a raster attribute table
Summary
When a raster dataset that has more than 65,536 unique values is rendered, an error message may display that there are too many unique values. Instructions provided describe how to increase the maximum number of unique values allowed in a raster attribute table.
Procedure
To edit the unique values for a raster attribute table, follow the steps below:
  1. In ArcMap, click Customize > ArcMap Options.
  2. In the ArcMap Options dialog box, click the Raster tab, and click the Raster Dataset sub-tab.
  3. In the Maximum number of unique values to render parameter, insert the desired maximum number of unique values.
An image of the ArcMap Options dialog box.
By default, the size of a raster attribute table is limited to 65,535 unique values.
  1. Click OK.
Article ID:000010117
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
