English
Bug: Performing a selection against a view containing a st_geometry attribute results in a Network I/O error
Performing a selection or identify with ArcGIS against a registered view with a st_geometry attribute results in a Network I/O error (gsrvr fatal).
Cause
Because the view contains an st_geometry attribute, the SQL statement being constructed by ArcSDE contains an extra attribute referenced in the SELECT list, named points, which causes the gsrvr process to crash.
Workaround
Create a table from the view and register the table with ArcSDE as a layer.
