English
Problem: ArcSDE for Informix hangs when importing a raster dataset
When importing a large raster file, the import stops and the program is locked and has to be restarted.
Cause
The Informix database does not contain enough free space in the DBSpace to which the raster is being imported.
Solution or Workaround
Add more chunks to the DBSpace. Consult the IBM Informix documentation for instructions on adding a chunk to a DBSpace.
    Related Information
