BUG
When using the ArcIMS Manager for the Microsoft .NET Framework, the Preview Map and Define options on the Layers tab do not display images for non-cached services. This problem occurs on Windows XP, Windows 2003, and on Vista/Windows 2008 when using the Classic mode of IIS 7.0.
The ArcIMS Manager application is referencing an incorrect DLL version.
Code:
<add verb="*" path="ESRI.ArcGIS.ADF.Web.UI.WebControls.MapHandler.ashx"
type="ESRI.ArcGIS.ADF.Web.UI.WebControls.MapHandler,
ESRI.ArcGIS.ADF.Web.UI.WebControls, Version=9.3.0.1542,
Culture=neutral, PublicKeyToken=8FC3CC631E44AD86" validate="false" />
Get help from ArcGIS experts
Download the Esri Support App
