English
Error: FDO_E_SPATIALFILTER_INVALID_GEOMETRY (-2147216814)
Error Message
Setting the Geometry property of a spatial filter to null (or Nothing, in Visual Basic) returns the following error:
"FDO_E_SPATIALFILTER_INVALID_GEOMETRY (-2147216814)".
Cause
Prior to ArcGIS 9.3, the Geometry property of a spatial filter could be set to null. At version 9.3, additional error checking was added to prevent the property from being set to an invalid geometry with a null geometry considered as invalid.
Solution or Workaround
To perform a query without spatial constraints, there are two options:
1. Use the QueryFilter class along with the IQueryFilter interface, instead of a spatial filter.
Code:
// Create the query filter.
IQueryFilter queryFilter = new QueryFilterClass();
queryFilter.WhereClause = "PROPERTY_ID > 3000";
// Execute the query.
featureClass.Search(queryFilter, true);
2. Do not set the spatial filter's Geometry property. By default, it is already set to null.
Code:
// Create the spatial filter.
ISpatialFilter spatialFilter = new SpatialFilterClass();
spatialFilter.WhereClause = "PROPERTY_ID > 3000";
featureClass.Search(spatialFilter, true);
