Frequently asked question
Changes in List methods for Python with ArcGIS 9.3
Answer
In ArcGIS 9.3, the Geoprocessing Programming Model changed the way List methods produced results. In ArcGIS 9.2, they were outputted as enumerations, where the properties of Next and Reset were needed to iterate through the list.
ArcGIS 9.3 now produces Python Lists that do not require Next and Reset. Below is an example of the differences.
Using Next() and Reset() with List methods produces an error only if the script uses the 9.3 version of the arcgisscripting module.
Current scripts that utilize the 9.2 version are not effected.
These changes effect the following methods:
ListFields()
ListIndexes()
ListDatasets()
ListFeatureClasses()
ListRasters()
ListTables()
ListWorkspaces()
ListEnvironments()
ListToolboxes()
ListTools()
ListInstallations()
ArcGIS 9.2 ListFeatureClasses:
Code:
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = r"D:\Data"
fcS = gp.ListFeatureClasses()
fc = fcS.Next()
while fc:
print fc
fc = fcS.Next()
ArcGIS 9.3 ListFeatureClasses:
Code:
gp = arcgisscripting.create(9.3)
for fc in fcS:
print fc
Article ID:000010031
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
