English
Bug: Cannot export an XYEvent table contained in Oracle to a featureclass using an OLE DB connection
An Oracle 10g XYEvent table cannot be successfully exported to Personal geodatabase, File geodatabase or Enterprise geodatabase (ArcSDE). The schema gets exported but the data does not (the featureclass is empty).
This is a problem with both the Microsoft OLE DB Provider for Oracle and the Oracle Provider for OLE DB.
Cause
The extent returned by the providers is zero.
Workaround
Use the Oracle ODBC Provider.
