BUG
The Migrate Storage tool can exceed the Oracle default open_cursors limit of 300
The Migrate Storage geoprocessing tool (ArcToolbox > Data Management Tools > Database > Migrate Storage), when run on a batch of feature classes stored in Oracle, can exceed the Oracle open_cursors default limit of 300. When this happens, the tool returns the following generic message:
"ERROR 000955: Error encountered migrating the database storage of <connection>
Failed to execute MigrateStorage."
In addition, the SDE error log contains a message stating that the open_cursors limit has been exceeded.
Cause
Oracle cursors are incorrectly left open during the conversion of each feature class. Converting 200 or more feature classes can open enough cursors to exceed Oracle's default open_cursor limit of 300.
When the tool finishes migrating a batch of feature classes, the cursors are freed.
Workaround
Increase the Oracle database parameter open_cursor, or decrease the number of feature classes in the batch converted with the Migrate Storage tool.
To increase the open_cursor, connect to Oracle as the SYSTEM user and issue the following SQL statement:
Code:
ALTER SYSTEM SET OPEN_CURSORS=2000 SCOPE=BOTH;
Article ID:000010009
Software:
  • ArcMap 9 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
