English
Bug: ArcReader's status bar doesn't display Decimal Degrees and DMS to the same level of accuracy as ArcMap.
ArcReader only shows two decimal places in the status bar, even if the MXD is set to show more.
Cause
This is a known limit.
Workaround
To view more than two decimal places, use the Identify window.
