HOW TO
Run ArcIMS components as 32-bit applications on 64-bit Windows
Summary
Although ArcIMS 9.2 and later version are certified and supported on 64-bit machines, it has been found that certain required components for the installation of this product do not work in 64-bit environments (mainly Windows 64-bit operating systems running on machines with Xeon processors).
By running IIS in 32-bit mode, these components can be installed and operate properly.
Procedure
For information regarding running IIS in 32-bit mode and using 32-bit Web applications on 64-bit machines, refer to the Microsoft Knowledge Base Document link under the Related Information below.
    Article ID:000009979
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
