English
Error: RegCat Run-time error '-2147024770 (8007007e)': Automation error: The specified module could not be found
Error Message
When installing ArcGIS Desktop, the following error is received:
"RegCat
Automation error
The specified module could not be found."
Cause
This error is caused by a problem with the Microsoft Script Runtime Library.
Solution or Workaround
Manually register the Microsoft Script Runtime Library by following these steps:
  1. Click Start > Run.
  2. Type CMD and click OK.
  3. Type the following and press the Enter key:
    Code:
    regsvr32 "c:\windows\system32\scrrun.dll"
  4. Close out of the Command Prompt and restart the ArcGIS Desktop installation.
