PROBLEM
The Interactive Selection button is grayed out
Unable to select features due to the Interactive Selection tool and other selection options being grayed out.
Cause
There are no layers added to the map document or there are no selectable layers.
Solution or Workaround
Set the selectable layers by clicking Selection on the Menu Bar and choosing Set Selectable Layers. Check the layers to be selected.
Selectable layers can also be set by clicking the Selection tab at the bottom of the Table of Contents.
[O-Image] Selection Tab
    Article ID:000009942
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
