English
Bug: Objects in this class cannot be updated outside of an edit session
When using the Calculate Field tool on a feature class that participates in a join stored in an ArcSDE Enterprise geodatabase, the following error message will be returned:
"Objects in this class cannot be updated outside of an edit session."
Cause
This is a software malfunction.
Workaround
Start an edit session, prior to running the Calculate Field tool.
